1998 civic wont start
Discussion in 'Civic and del Sol - EG and EK' started by 1chiko3, Mar 14, 2010.
  1. 1chiko3
    1chiko3 New Member
    i have fuel and spark , car just died in freeway can anyone help :(
  2. SLP10
    SLP10 New Member
    Check oil level, check alternator/battery for output. Check grounds, possible you have very weak spark, check plugs and wires a second time. how many miles? all stock?
  3. DESPAIN
    flower mound TX
    check the timing belt..........
  4. BrutalB83
    Rochester Hills, MI
    This forum is for 2001+ Civics. I'm moving this thread to the proper location...
  5. ricksautomotive
    ricksautomotive honda dealer tech
    lancaster, ca
    i'm guessin the problem was fixed? if not let us help. how many miles? did you check the timing belt?
  6. droszyk
    droszyk New Member
    Chesapeake, VA
    Does the car even try to start? It may be the crank sensor if you can get it to turn over at least. More information is needed to help. The more details you give the more help will be given.
