2.7 engine swap
Discussion in 'Accord' started by bottom line joe, Jan 12, 2012.
  1. bottom line joe
    bottom line joe New Member
    Can you put a 1998 3.0 in a 1996 accord which had a 2.7 in it?? If so what needs to be changed.
  2. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    I am sure you could but that is more work than it would be worth. Not only would you have to make all of the mounts etc you would have to figure out the drive line set up for cv shafts and all of the wiring....besides those motors are turds.
  3. bottom line joe
    Is the bellhousing the same ? Is there anyone who has done this before??/
  4. powerdriverh22
    spfld, mo
    no and no, there is no use. the 2.7 is crap and so is the j30 in those cars. scrap it and get a 4 banger to put an h22 or something in.
