2000 Si brakes on a 95 ex
Discussion in 'Civic and del Sol - EG and EK' started by Stizzi, Feb 8, 2009.
  1. Stizzi
    Stizzi New Member
    Just picked up a complete brake swap from a friend. Everything is included except for the prop valve (he even threw in a powerslot big brake upgrade for the fronts too:)). I have installed everything on the front (spindle, calipers, rotors, big brake kit, pads) except for the prop valve and mc/bb. The mc off his si is a 7/8 as is the one off my ex, so i didn't change it out.
    Due to certain circumstances, I need to get the car back on the road, so the rear disc swap is going to have to wait. My problem is that I have no pedal pressure and no brake power at all.
    I've been through the entire system: no leaks, no air, and still no brakes. I've bench bled the master cylinder and the lines several times now. Any ideas as to what the problem could be?
  2. serrilion
    serrilion In my own little world! VIP
    Vermont
    did u install the pads? lmao
