2000 Si Cranking but wont Fire.
Discussion in 'Civic and del Sol - EG and EK' started by double0Si, May 3, 2009.
  1. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
    PRE No-Start: I pulled the spark plugs (one at a time) just to check and make sure they were all in good condition. They all looked fine so I buttoned everything up and went to start it up. Well its cranking but it wont fire. I didnt pull anything other than one plug wire at a time and only from the spark plug itself. I went over all the connections and everything is as it should be. I switch the key on and the main relay switches on. This is all 10-15 minutes after I had been driving it for about an hour or so... Any thoughts?
  2. double0Si
    Columbus, Ohio
    disregard! delete, close, cancel. solution was not even worth posting. I wish it was only as dumb as a loose wire. There is definetly an I in FAIL...
  3. phyregod
    phyregod !!YTINASNI
    Central Texas
    Now you have to fess up. Smash an electrode?
  4. double0Si
    Columbus, Ohio
    lets just say it was as easy as turning the car around to face the opposite way. can you guess why?
  5. frodotoolbox
    frodotoolbox 92 civic si d15b
    sc
    you switched some wires on accident???
  6. double0Si
    Columbus, Ohio
    I don't know how turning the car around would fix that... but no, all wires were correct. worse than that
  7. civicsiserge
    civicsiserge New Member
    Oregon
    forgot to press the clutch? lol
  8. double0Si
    Columbus, Ohio
    nah it was a stupid mistake, not a braindead one
  9. TurboMirage
    you mistook your pontiac for an Si? :)
  10. double0Si
    Columbus, Ohio
    ouch! though the headlights look similar to the G6 when the hoods up, no mistaking it for a Pontiac. good guess though lol
  11. sneakerfile410
    sneakerfile410 Banned
    Wholesale Nike Shox Shoes
    :spam:
  12. frodotoolbox
    sc
    no f-ing clue... just tell us!!!!!!!!!!!!
    it might be the same thing thats wrong with my car.
  13. phyregod
    phyregod !!YTINASNI
    Central Texas
    Parked on a hill and almost out of fuel?
    1 person likes this.
  14. double0Si
    Columbus, Ohio
    F'N spam! this was almost buried lol
    Yes. I was that stupid. It was at most a .5 - 1% grade driveway in front of work. I was on my way to the gas station and decided to use works tools to check and see if I needed new plugs while I was out. Rep for solving the great mystery. Frodo, if this is what's wrong with your car just off yourself as I should have.
