2000 si
Discussion in 'General Tech and Maintenance' started by redef91, Feb 22, 2009.
  1. redef91
    redef91 Senior Member
    Boston,Ma
    i had a ? i just purchased a 2000 si off one of my buddies, i was driving all day yesterday and the check engine light came on. i called him up and he said if vtec still works than its probaly a o2 sensor, is this true or could there b something mech. wrong with the motor. :confused:
  2. George777
    George777 ^^ Likes Bewbies
    With your mom
    Get the code read. If you don't have a scanner, then go to Advanced Auto or some place that will scan the code for you and see what it is.
    The CEL controls more than just O2 sensors and vtec.
  3. redef91
    Boston,Ma
    thanx ill check the code and see what it is.
  4. George777
    With your mom
    Ask them to write down the codes for you, so you can research them more. I've witnessed a few times where they have told customers what parts to get, but never what the code was.
  5. redef91
    Boston,Ma
    they said it was code 67 which they said o2 sensor after the cat.
  6. George777
    With your mom
    It's a good place to start. Replace it and see if that solves it.
  7. redef91
    Boston,Ma
    ill try it and see what happens.:D
  8. 97hatch
    97hatch ?
    Anderson IN
    does your car even have a cat and secondary o2 sensor if they have been removed that could also be your problem
  9. redef91
    Boston,Ma
    no it diff has a cat and secondary o2 sensor i mean the vtec is still popping so idk know maybe the sensor went bad. it does have ctr pistons and ctr inake cam,that were just installed about a months ago but i dont see why it would throw a cel light now. ive been driving it for a month now. any ideas:confused:
  10. Briansol
    o2's go bad. and more so, the 2ndary is a checker o2... it takes the pre-cat reading and expects it to be X cleaner after the cat.
    if it's not, it will throw a code.
    when you got into modding heavily, it puts out more exhaust than it expects.
  11. redef91
    Boston,Ma
    so if anything the o2 sensor is getting more air than not right with those mods?
  12. redef91
    Boston,Ma
    does that blox cel o2 sensor spacer even work i mean i will try it if it works...
