2001 acura 1.7 EL engine swap
Discussion in 'HYBRID -> EP / DC5' started by blahblah, Jan 2, 2010.
  1. blahblah
    blahblah New Member
    I am not that accustom to hondas so I was wondering if someone could answer me this. Could a 3.2 V6 engine be swaped in for my 1.7 easily?
  2. 99sidude
    Ohio
    You would need to custom fabricate everything yourself. It would be extremely expensive and time consuming. Look into a K series swap instead.
  3. PhyRe
    PhyRe Senior Member
    ct
    not that i know much about the el but its a cross btween a civic and accord. someone makes mounts i think hasport for the v6 in an eg/ek so it might not be as hard as no info^ says google search the civic swap first ull find alot more info that might help
  4. 99sidude
    Ohio
    The el is exactly the same as a civic. badge engineering at it's finest. It has nothing in common with the accord.
  5. PhyRe
    PhyRe Senior Member
    ct
    style wise is more what i ment they put the clasic style of a ek and 96ish accord together
