imprtedcivic
ok guys. i have a 2001 base lude, motor is fucked. need a new motor and decided to go with the h23a vtec bluetop from japan.
The car must stay OBD2. Or if it will pass emissions being converted to obd1 then i can do this.
I need to know what i have to do to make this swap work. i know i need to do some things with the dizzy.
the car would need to be tuned. i was told the only way to really do this is to go obd1. or some gimic piggyback, is there anything i can do for this?
also im replacing the trans with an lsd trans. anything need to be done to the car to make the lsd trans work?
yes i know im new. but ill try to conribute as much as possible
thanks
thanks
