i have a 95 dx coupe. with a lame-o 1.5.
1. how do i reset my check engine light? 2. i keep overheating and i already changed the leaky radiator. what next? 3.how do you identify a transmission?
1. undo the battery terminals for about 15 minutes
2. check your thermostat, make sure it's opening
3. there should be a barcode on there with a code written on it, check it against what you find here. the tranny code should be near the clutch actuator assembly.
