350 WHP LSVTEC Swap for your Civic
MrToasty
Stock JDM B16A Head with B18B Block. (LS-VTEC)
• Engine bored .020â€/0.5 mm
• Eagle Rods w/ ARP rod bolts
• CP Pistons - 9.0:1 Compression
• ACL Rod and Main Bearings
• Type-R Water and Oil Pump
• ARP Head Studs
• Cometic Head Gasket (Standard thickness)
• Golden Eagle LS/VTEC Conversion Kit
• C&R Aluminum Half Radiator
• Perma-Cool 1650 CFM Fan
• Slowmotion Triple O-Ring Cam Seal
• Polished Slowmotion Spark Plug Wire Cover
• 1999 Civic SI Transmission (B16/S4C)
• Clutchmasters Clutch and Pressure Plate
• Golden Eagle Vacuum Manifold
• Custom Black w/ Silver Flake Du-Pont Powder Coated Valve Cover w/ Polished Emblems
Performance Parts:
• Garrett T3/T04B .60A/R Compressor, .48A/R Turbine
• Drag Cast Iron Log Manifold
• Hondata S300 w/ Boost Control
• GM Solenoid for Boost Control
• Tial 38mm Wastegate
• Large Bar/Plate Front Mount Intercooler (unknown brand)
• Custom Aluminum Intercooler Piping and High Quality T-Bolt Clamps
• Custom 2.5†Stainless Steel Down pipe/Flex Pipe/Dump Tube
• 3†Thermal Research & Development Cat-back Exhaust (stainless)
• Blitz Blow Off Valve
• Stainless Turbo Oil-Feed Line
• Precision 780cc injectors w/ resistor pack
• Walbro 255 LPH Fuel Pump
• 3-Bar MAP Sensor
• K&N Air Filter
• B&M Black-Out Water Temp Gauge
• Autometer Air/Fuel Gauge (not Installed)
• Dual Gauge Pod (Around Instrument Cluster)
• Unorthodox Power Steering Under drive Pulley
I need a complete D16Y8 Swap (Axles, ecu, tranny, wiring harness, complete exhaust, etc... ) (preferably under 100k miles) for this swap + $3500.
This is absolutely everything you need to get 350 wheel horsepower in your civic. My swap, for yours. Talk about a simple weekend job. The fastest and most effective upgrade ever. Plus you don't have to spend any time/money on a dyno because the tune is already done by Slowmotion Motorsports and saved into the S300 in the ECU! Seriously- A drop and drive swap.
Engine runs at 350whp @ 16 psi on 93 octane pump gas.
Engine burns a bit of oil... approx. one qt per 500 miles, but still gets 30 mpg on the freeway! Adding a bit of oil every week never bothered me and even with full sythentic oil i was spending less than 10 dollars a month on oil. Still a great deal, and the engine only has 6k miles on it. Come test this engine out in my car before buying, if you like.
MrToasty@columbus.rr.com or PM or text me at 614-595-6430
Thanks.
-Mike
http://hondamarketplace.com/showthread. ... st36450824
See this post for pictures.
