+40 hp
Discussion in 'Engine Building' started by Tenzodelsol, Apr 12, 2004.
  1. Tenzodelsol
    Tenzodelsol Member
    Idaho
    I had my sol tested on the dyno today and with the header, cam gear advanced 3 pts,cat back, and intake I found that shes cranking 139.8 horsepower, now I am planning on running a turbo with 7 lbs boost but I am not sure if that will give me what I want
    the question is where can I come up with 40 hp. my goal is 180 horse to put me somewhere in the mid 13s
  2. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    Even a t3 setup would give you that much.
  3. pissedoffsol
    40hp out of a t3 setup is more than easy to do... but you might want to turn that cam gear back
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    What motor is that? 139 is low for a B16A, and 139 is too high for a D16Z6.
  5. Del Slw
    Del Slw Member
    Cincinnati, OH
    kid i know had a t3t4 .50 trim on his d16z6, and at 6.5psi he had 178whp on a mustang dyno
  6. ek9r
    ek9r Senior Member
    Long Island NY
    boost that thing. then you get to throw away 2 out of the 4 mods you just bought :thumbsup: a t3 would be a good start
  7. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    sounds like a sohcer to me, from his post
  8. Tenzodelsol
    Tenzodelsol Member
    Idaho
  9. xj0hnx
    C.C.TX.
    You want us to believe that a 125hp at the crank SOHC, dyno'ed at 139 to the wheels with I,H,E and 3 degrees timing advance? Riiiiiiight
  10. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    and you want me to believe that 180 whp will net 13's in a del sol??
    nope.
    i have 184 whp in a del sol that weighed somewhere around 2500 lbs w/ me in it and went 14.2 - 14.3 @ 99.999999 all day long
  11. Tenzodelsol
    Tenzodelsol Member
    Idaho
    alright through some calls and shit I guess I was misunderstood and that is supposed to be the HP at the crank not at the wheels at the wheels I guess I should be running right around 120-125, as for quarter mile I have removed the AC, passenger seat, spare, interior cubbies, and the top, thats also with only 1/8th a tank of gas and a CF hood, I estimated the car to be about 2000 lbs and used the quarter mile time calculator on a link at this site so most of this is prediction but anyway my goal is to get this sol to run the strip in 13.anything
    And yes for those of you who dont know I am a nooB
  12. NotUrAverage_Si
    NotUrAverage_Si Senior Member
    yes we know. :)
  13. Dustin_m
    Dustin_m Active Member
    San Diego, CA
    I knew soemone would think that stupidass 1/4 mile estimator was accurate. That thing is a POS and is not correct, dont believe it.
