4000 hp integra
Discussion in 'Auto Multi-Media' started by 97hatch, Mar 27, 2006.
  1. 97hatch
    97hatch ?
    Anderson IN
  2. pissedoffsol
    very much a repost
  3. josuedc2
    josuedc2 Senior Member
    Buffalo,N.Y
    is that a vtec motor?
  4. Celerity
    Celerity Well-Known Member
    Nothing about that car is Acura.
  5. GSRCRXsi
    MD
    not true. the "A" is still there
  6. dveit
    dveit Well-Known Member VIP
    DMV
    [​IMG][​IMG][​IMG][​IMG]
  7. ScrapinSi
    ScrapinSi Senior Member
    It started out as a full bodied ITR, but has since been totally changed...
    5.4 Litre Twin Turbo 4 Cylinder Nitromethane
    D16z6 Rod next to H22a Rod Next to Norwood 5.4 Rod
    And it actually does its start, idle, burnout, and backup on Ethanol, then switches over to Nitro...
  8. TurboMirage
    its running MoTeC. hawwwwwt.
  9. endlesszeal
    endlesszeal Senior Member
  10. reikoshea
    Dallas, TX
    did he make a new block cause the video says 4.8L SOLID (no water cooling) I4.
  11. GSRCRXsi
    MD
    from the looks of it, looks like a a fully custom block. with the bore hes running i dont think it would be possible to do without getting a new block. i imagine that making a bore that large would require spacing the cylinders out more.
    and running on alcohol, you dont need coolant. its burns so cool. not sure if thats true with nitro or not though.
  12. reikoshea
    Dallas, TX
    it is a custom block...i can guarentee that.
  13. Capt. Orygun
    Capt. Orygun Win the Day
    Oregon
    It's fucking gay IMO, I'd rather watch amateur FWD NA drag
    Professional drag racing makes my dick soft
  14. reikoshea
    Dallas, TX
    yeah...burn outs are better than the race.
  15. GSRCRXsi
    MD
    except top fuel. i LOVE top fuel. not really for the races. mainly for the egines. something about a compression ratio so high that the a/f mix turns to jelly and running on verge of hydro lock as a result just seems badass to me.
  16. ScrapinSi
    Not to mention the fact that any motor that can burn 25 gallons of NitroMethane in 4 seconds is pretty hawt... And having injectors that flow more fuel than your average garden hose... :mrgreen:
    And yes it is a custom block built from a gigantic slab of aluminum.
  17. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    at that point vtec would hurt the engine capability
  18. vanillakilla
    vanillakilla Senior Member
    Tacoma Washington
    I wouldn't want to drive that thing something about it is screaming death-trap at me. what times do those run
