What injectors for me knowing that I'll want to turn up the psi after I build bottom end. This is for a b18c1 with stock internals, until spring, that I'm going to run a t04e with 57 trim wheel, .63a/r exhaust, and .50 a/r compressor housing. Going to be using hondata of course. The goal is 300 whp tuned on the dyno with my stock internals. Will I outflow the 550's if I want to run 13psi or so on pump gas after the build, or will the 650's be to much for the stock motor? Thanks.
