6th gen swamp?
Discussion in 'HYBRID -> BA-BB /CA-CD' started by Operating_Engineer, Mar 19, 2004.
  1. Operating_Engineer
    Operating_Engineer Junior Member
    whats the best swamp for a 6th generation accord. I currently have a 99 lx sedan,
    5 speed. Is H22 an option, if so do i have to change the tranny? Thanks
  2. tab
    tab Super Moderator
    Aberdeen, Washington State
    Keep your tranny. Buy a H22 from a 97+ Prelude(OBD2). Enjoy. With minor modifications, everything will bolt up and work. Try to get an ECU to match that motor. Since you are already OBD2, try to stay that way. Don't buy a 92-96 JDM motor because it's cheaper. Expect that swap to cost you hundreds more in the long run.
    Also, H22 is your best option. Very feasible and doable. V-6's are out of the question cost wise. Turbo applications are also worth consideration.
