86 crx si pr3 ecu gsr swap
1stgenBone
Bought a 86 crx si with a gsr swap. Need some help on an issue I'm having with the throttle or map sensor not too sure.
Badass car man I love it, I would start with any check engine codes if it is throwing one, and if not throwing codes id go over wiring really well, that's part of the downfall of buying a car swapped by somebody else into an older chassis but you will get the bugs worked out and please post more pictures that thing is sweet
