87 CRX SI W/87 TEG MOTOR SWAP?
Discussion in 'HYBRID -> ED-EF / DA' started by CRXCIRCLETRACK, Jul 12, 2004.
  1. CRXCIRCLETRACK
    CRXCIRCLETRACK Junior Member
    I have a 87 civic si with a 1.5 and a 87 teg with a dohc 1.6. im not sure which version the motor is in the teg. I was wondering if the swap was possible or if it was even worth it?? Any help would be appreciated :D
  2. RSBAD454
    RSBAD454 Member
    here you go Noob.....G1 CRX Forum but the answer is yes......if it is the 88-89 Teg motor in your 87 Si. The motor from the 87 Teg will bolt right in , but the electronics arent compatible like the 88-89 Integra D16A1.
  3. CRXCIRCLETRACK
    thank you for the link. I am going to start the swap soon. The little 1.5 gave up :(
  4. RSBAD454
    RSBAD454 Member
    Yeah, make sure you install a 88-89 Integra Motor though......
  5. racintweek
    racintweek Senior Member
    Arlington VA
    wrong
    you need the 86-87 teg engine
    1G rex's had vacuum advance ignition, same as the 86-87 teg
    the 88-89 tegs had electronic advance ignition
    totally diff electronics
    the blocks are the same so they both bolt in
    but the dizzy's, wiring and ecu's are different
    save your self the hassle and get the 86-87 engine
    i know the you are thinking the 88-89 has 8-10 more hp but
    dont think about swapping the dizzy from the 86-87 to the 88-89 because the holes in the head dont line up
