I picked up a 87 Integra (86-97 D16A1, aka Browntop ZC) with blown valves (timing belt went).
I can pick up a 88 head with its dizzy and sensor (and maaaaayyybe ecu) for a good price from a stmotorsports. (d-series.org)
His ecu has been flooded and might not work (assuming he could even find it).
I'm curious if I can swap on the 88 head, mount my 87 dizzy to the 88 head with a single bolt (until i get an adapter or make one), and wire in the 88 crank angle sensor to my current harness/ecu. This thread on d-series.org ( http://www.d-series.org/forums/showthread.php?t=10106 ) does exaclty the opposite, take a 87 dizzy and put it on an 88. If that works, the other way should work to.
Will this combination work?
Thanks,
Hyperi0n
Thanks,
Hyperi0n
