First of all, I don't think the "right wheel being closer to the transmission" has nothing to do with the pulling since it is the length of the axles what matters (considering they are identical...). Torque steer should only manifest itself when the steering wheel is not straight an it tries to center itself, or when on wheel looses traction. IMO, I can think of a couple of reasons why your car might be pulling consistently to the right.
a ) Wheel-alignment,
b ) Engine-alignment,
c ) Incorrect axles,
d ) Failure to remove bearing cover from hub and spacer from correct axles (see Hasport for instructions),
e ) You're driving on a banked surface.
I have the same engine in my car an it does not pull. Hope in helps.
