88 DX to 89 Si
Hey,
I just finished hooking everything up, turned the key....... and nothing.... the starter cranks, but the engine doesn't seem to be firing.
I am getting code 10... Intake Air Temperature,
and code 20.. Electrical Load...
Can anyone please give my some advice on how to fix this problem? Can I fix Code 20 by replacing the engine ground straps with better ones???
Thanx,
D
code 10 sounds like you didn't do the wiring exactly right. and code 20...... hmm could be a bad altenator or battery. you could try grounding better but I doubt that will help.
