06 (70)
It's for '92-'95 but the procedure's the same.
I just started doing this and it works pretty good. I set the #1 cylinder to TDC via the mark on the crank pulley and set the lash on #1, the intake of #2, and the exhaust of #3. Then I rotate the crank 360* (the cam gear will rotate 180*) using the TDC marker on the crank pulley to line it up and I set all of #4, the intake of #3, and the exhaust of #2. It saves a few minutes and it's a lot more accurate than just sticking something down the spark plug tube.
