It's not much harder than a domestic late-model V8. Probably easier actually. Get yourself a $10 Haynes manual from autozone or advance(90-93 Accord), or better yet, the authorized Helm Factory Service manual for your Accord.
Read through the Engine and transmission removal procedures, several times, removing them both as a unit.
Before starting, I recommend labeling all connections(vacuum and electrical) and separating all mounting nuts and bolts, labeling them appropriately. Take plenty of before pictures with a digital camera if you've got access to one. Something else that's helpful is placing a vertical Scotch-tape strip next to all the steps in the manual and checking off each step with a grease pencil as you finish them, ensuring all of them are completed.
Once the engine is out, take the time to clean up the engine bay. I always work at the Base hobby shop, so all I have to do is roll the chassis out to the car wash. Soak it good with degreaser ahead of time, then a foamy brush and high-pressure rinse will make it look factory-new (well, almost
When installing the H22a, installation is EXACTLY the reverse of removal. You will, however, need to add 4 wires from the engine to the ECU unless you use an H22 harness. They are: VTEC oil press. sensor(2 wires), VTEC solenoid activation(1 wire), and knock sensor(1 wire).
Paragus, BlackJDMdeath, dohcvtec_accord: help me out if I'm missing anything.
Start it up, you're done. Hopefully it won't even take longer than a weekend... not 4 months like my brother
nimblecivic's B16A swap.
Hope that helps. If you looks at my sig, you see I have no prejudices (except Fords :unsure: )
