90 accord tranny problems
Discussion in 'Accord' started by sxyhnda, Jun 11, 2008.
  1. sxyhnda
    sxyhnda New Member
    i have a 90 accord with F22 5-speed. the tranny is shot and was considering upgrade to a tranny from h23 or h22. i was wondering what would be best/easiest, and would it even be worth the trouble to go w/ tranny from prelude
  2. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    IIRC there are H series trans' with LSD's in them. Try searching one of those out :)
  3. BrutalB83
    Rochester Hills, MI
    Correct sir. Some of the JDM H22A transmissions had LSDs. You can get one through any of the engine importing sites...
  4. sxyhnda
    sxyhnda New Member
    is the gearing shorter on a h22a trans? does anybody know how i can get the specs on them? i have a stock motor and need all the help i can get.... lol also how easy is the install on one?
  5. BrutalB83
    Rochester Hills, MI
    Yes, the gearing is shorter. For the specs, just do some searching. I know somebody posted something about this not too long ago. Also, there may be an article in the reference section about gear ratios. Well, I know for a fact there is but I don't know if the F/H-series is covered.
    Installation is exactly like stock. F and H-series engines and transmissions are completely interchangeable (aside from the S2000 drive-train). If you have a repair manual for your Accord then just follow the directions there.
  6. sxyhnda
    sxyhnda New Member
    nice.... so a jdm h22 trans with a LSD is my best option? where would be the best place to pick one up?
  7. VROOM_PSHHH
    VROOM_PSHHH New Member
    I thought that you had to mod the h tranny to bolt in the cb chassis... :confused:
  8. BrutalB83
    Rochester Hills, MI
    No, it's a bolt-on. How would you "mod" a tranny to fit a certain chassis anyway?
  9. sxyhnda
    sxyhnda New Member
    i think what he meant is are the mounts the same? my accord has 2 mounts from the chassis to the tranny. are these going to work the same on an h22 tranny? or will i have to rig something?
  10. BrutalB83
    Rochester Hills, MI
    Unless you're swapping from auto-to-manual you shouldn't need to change anything...
  11. sxyhnda
    sxyhnda New Member
    i'm seriously considering swapping a jdm h22 tranny with the lsd.... where would be the best place to find one? are they hard to come by and are they expensive? i know my car top to bottom but i'm new at this modifying and swapping thing, so i don't know exactly where to find parts......
  12. BrutalB83
    Rochester Hills, MI
  13. sxyhnda
    sxyhnda New Member
    id like to elaborate on my situation a bit.... as said b4 i have a 90 accord, f22a1 5 speed. the tranny works fine under normal driving, just as good as new. yet when driving it hard it refuses to go into second until the rpms come down. speed shifting is out of the question.... third grinds when shifting hard at high rpms, and has done so for some time, but it will go in with some force. 4th is always fine, and 5th grinds on occasion. it also refuses to go into first sometimes, such as when stopped at a stop light. i don't know much about trannies..... is this a synchro problem? is there anyway it could be the linkages? i had some problems with them a while back when i rebuilt the motor... any input helps......
  14. H2B Hatch
    H2B Hatch New Member
    Dude i'm trying to sell a jdm h22 trans. It's not lsd but I'm selling it pretty cheap. It grins a little in 3rd but not bad at all. If you are interested let me know. About 60k on it. Letting it go for 500. They're 6-800 on ebay. Will send pictures if you are interested, and answer any ?s you may have.............
  15. sxyhnda
    sxyhnda New Member
    i got a lot of other cosmetic work to do on my car b4 i start this tranny project. i'm sort of just researching and looking into my options at the moment. beside i don't think i have the money at the moment to even buy a tranny..... thanx anyway man.
  16. 93AccordEX
    93AccordEX New Member
    Hey thats mine!!! :D:D:D Just kiddin tho i dont think ima need it dude im gunna buy the whole swap with the lsd from hmotorsonline
