I am working on a 90 Civic hatch that my brother gave me and my buddy is gonna sell me super cheap a b16z6. I need to know will it fit and what kinda modifications i need to do to make it work. Any help would be greatful.
if its the sohc d16z6 then it will bolt up to your mounts and tranny. you will then have to eitehr modify the wiring harness of replace with one from the original motor.
the b16a with require new motor mounts because its a different style engine. it will also require i new transmission,shift linkage,and cv axles but that should all come with it.
It's a d16z6 and i'm using the tranny that's on it. hopefully switching to a hydraulic clutch isn,t too hard. otherwise i'll use the same tranny. and how complicated is it gonna be to switch the wiring harness
