90 crx,b16a swap runs like sh!t
04evolution
has trouble starting, once starting it cuts out when you floor it but if you ease into it, it run fine, untill vtec is suppose to kick in then it cuts out. Every once in a while it will run fine then all of the sudden it will start to cut out again. i have a aem fuel rail with adjustable regulator and i need to know what the fuel pressure should be set at.
did you do the wiring correctly? switch the tps wires around? is the dist. good?
used the si harness and everything is wired correct. this is the second motor in this car the first on ran fine untill it blew up
