90 si rear discs
GlassHeadlights
West West Yall
i found a 90 teg thats smushed to nothing (In the front) and i want to put the rear discs on my 90 civic si. i found this website that tells me mostly what i need except i thought i had to use the booster and master cylender off the teg .do i if i'm using the stock discs on the front of my si?
this is what i found.
FourthGenHatch
you should, but dont have to. get the proportioning valve off the teg if you can, that's more important than the master cylinder and booster.
upgrading the cyl and booster will give you a stronger pedal
not NEEDED but definitely nice :)
same goes for the prop valve
he's right about the pedal, because a larger master cylinder will move more fluid per unit of travel at the pedal. the converse is true also, a larger piston in your caliper will require more fluid to move, and require more pedal movement to get the same distance traveled as the smaller piston.
the proportioning valve however, limits fluid to the rear brakes, to keep the balance of front/rear braking. a wheel cylinder and a caliper require very different amounts of fluid to get the same clamping/expanding force. this will have no noticeable effect on pedal travel or feel.
alright i'll get all of thoes things , but just one more question, in the integra rs ls and gs do they use all the same brakes? because i was wondering if the gs might have bigger brakes.
90-93 are all the same i have all 3 years "90 da 1 is a 4door and 91 is a coupe "93 is a gs-r coupe i converted
Just use the master cylinder from a 91 ex civic. It'll bolt to your stock booster perfectly and it's a 15/16... save yourself the time from switching out the booster. Make sure you also get the non abs 40/40 prop valve from the integra...
where do i look fo the 40/40 stamp on the prop valve? would it be visible from looking at it in the car, in otherwords are you braindead if you cant see it right away?
well i went and got them today, sort of. it figured he had abs so i couldn't take the prop valve and MC/booster, i'll have to get them off another car, i'll be looking. he also had momo ajustable lowering suspension, should i take it?
whats a ex? i live in canada so they dont exist. what motor do they have?
wow, that guy painted ONE dust shield and ONE caliper. those might not be from the same vehicle... me and my over-observant insanely obvious observations.
he said the painted one is from the factory never been removed from the car, and the other is from a '93 rs. PLEASE dont tell me i f**ked up. before he piled it he JUST put new rotors and pads on it:D i'm going to take em apart and clean everything up and paint just the calipars red. is that a ricer thing to do?
the only 4g civics we have in canada are the CX DX and Si (hatchback). CX is very, very basic, dx is a bit more nicer (CX and DX have D15b2 engines) and si (d16a6) we also have the sedan only in DX and LX (D15b2) and the wagon which is only 2 wheel drive and D15b2 (i think might be 4wd and D16a6 i've never seen one) i know the '92-'95 civic ex is si in canada and the '96-'99 civic ex is si in canada. and in canada the sir is your si. its very confusing, i know
you didn't do anything wrong, however no dust shield/caliper is painted from the factory on these cars. some paints can actually impede the calipers ability to shed heat. i don't paint any for that reason, but most aftermarket calipers are painted from the factory. brembo, willwood, spoon, alcon, etc. so the heat issue probably doesn't outweigh the benefit of no rust. sometimes form follows function, in this case, maybe function isn't effected much, or at all.
