90 std with B16a and B16a Harness
NautiluS
I have a 90 civic standard; no a/c, no power steering. It now has the motor, transmission, axles, brakes, suspension all installed, but I have yet to wire it all up. I have an un-cut (complete) engine harness for the B16a from my SiR clip sitting in my garage. All of the wiring from the clip is completely intact as well.
SO...
This is my question. What do I need to do to modify the CAR'S harness to plug in the B16a ENGINE harness and everything work properly?
Besides rip everything out and send it to Hasport.
since the STD was dpfi you need to convert to mpfi as well as add vtec wires. technically you can not use the b16 harness. you pretty much need to use the d15 harness and modify it to work.
