Well i just I blew my b16a1 motor. My #3 piston took a chunk out my piston sleeves and the piston is no longer there. Its in my oil pan and it also messed up the head and valves on the #3 and valves and some others. So my dilemna is that Im kinda of broke and I found a b18a1 block and head for cheap. I was wondering if I could use all the parts of the b16a1 to make one engine such as the intake manifold, throttlebody, header, ecu, distributor and wiring harness.
