91 accord h22a1 build
Discussion in 'Accord' started by 91accordlx, Nov 2, 2009.
  1. 91accordlx
    91accordlx New Member
    ohio
    i have a 91 accord lx h22a1 auto what can i do for cheap to build some more hp/torque?
  2. f22b1 coupe
    f22b1 coupe Junior Member
    Indiana
    First, get a good cold air intake. Then get a header, like this:
    Bisimoto F22ax header group buy in special! - CB7Tuner Forums
    Then get a really good exhaust system. If that's not fast enough for you, buy a camshaft and put it on. Obviously change your timing belt, water pump, tensioners, and seals while you're in there.
    All of that, depending on whether you get good stuff or cheap stuff, will make you 30-60 HP and cost you $500 if you go cheap and maybe $1200+ if you buy expensive stuff.
    I don't want to assume you are a complete stranger to cars, but if you are, let me know and I'll explain in more detail.
  3. 91accordlx
    ohio
    i have a 2.50" exhaust i got of ebay high flow resonator no cat-converter 4" muffler, ebay header, 3" cool air intake so far . how well do you think they worked for me.
  4. f22b1 coupe
    Indiana
    Oh wait, I didn't get past 91 Accord somehow- H22 eh? Yeah you've got ~188hp to begin with, I'm sure with intake and exhaust you're up around 200 easily, maybe more like 210. To be honest, the thing that helps the H22 the most is cams (from what I've heard). It's not an easy job, or cheap, but that is the next "big step." You could also look into ECU chipping tuning, that is an area I am myself unfamiliar with, but there are a ton of people on this site who have done it. You could ask in the prelude forum and you might get a faster and more knowledgeable answer just because that's where the people that have done it are.
    You're off to a pretty good start, I'd say you should have a noticeable performance increase over stock. I'll give you a list of the order most people seem to go in, for what it's worth:
    Cold Air Intake
    Exhaust System
    Header
    Hot ignition system
    Hi flow cat/cat elimination
    ECU tuning/chipping
    Cams (sometimes requires valvetrain upgrade)
    Larger throttle body
    Ported/polished head
    Underdrive crank pulley
    As a side note, I'll say saving the reflash for last is a good idea, just because then you can tune your car for the mods you have and optimize the settings based on your unique combination of mods. If you did everything on that list, I promise you'd feel a night and day difference. You'd also be broke ass.
  5. BrutalB83
    Rochester Hills, MI
    How do you figure 188 horses? Bone stock H22s dyno around 150ish-160ish horses. I've seen ones with quality, name-brand bolt-ons dyno around 170ish horses, so I really doubt he's making 200 wheel horses with E-Bay parts...
  6. 91accordlx
    ohio
    i'm sorry its not a 91 its a 90 accord i pressed the wrong button but thanx for the info
  7. f22b1 coupe
    Indiana
    Oh, dyno- okay well I was just going off of this:
    Honda H engine - Wikipedia, the free encyclopedia
    Says 187HP, it had been awhile, I knew it was just a hair under 190. Anyway, I didn't realize we threw around dyno figures here rather than "rated HP." I wasn't trying to engage in misinformation, just going on what I have read. Also, I'm not too terribly familiar with the H22, hence why I suggested the Prelude forum/someone else answering. I did the complete timing belt job and manual tensioner conversion on an H22, but that is literally the extent of my personal experience with them.
  8. f22b1 coupe
    Indiana
    Btw brutal- do we have a list anywhere of stock WHP outputs for Hondas? I'm kind of curious what the average loss is.
  9. BrutalB83
    Rochester Hills, MI
    Ah, okay. Well if you were talking crank horsepower numbers then your figures may have been reasonable. A lot of the noobies on here aren't even aware of the difference between power at the crank and power to the ground though, so I just wanted to clarify.
    And as for the numbers, I really don't know if we have that info anywhere... :shrug:
  10. buttered corn
    buttered corn New Member
    good guess is 17~18% loss for FWD cars and ~20% for RWD
  11. BrutalB83
    Rochester Hills, MI
    Another good rule of thumb is about a 20% loss for manual transmissions, about 25% for slush-boxes...
  12. 22deuce
    22deuce New Member
    you can install k24 pistons
