TewSmooth18
Hello all,
I have a 91 Honda Accord 2.2L. I was driving the car and after driving for about 2 blocks the car died, it wouldnt start back up so I had it towed back to where I live.
I replaced the Main Relay (RZ-0088) and the distributor (which was on a 91 accord that WOULD start) from a junk yard. The car still won't start. I went and bought an Ignition Spark Tester and plugged it in, gapped it, and grounded it out and turned the car over, there is no spark at all.
I know that the timing belt is fine (as in not broke) as we pulled the oil cap off and cranked the car over and you can see the cam shaft (i beleive is what it's called) spinning.
Does anybody have any solutions to what the problem could be? The only other thing that I can think of would be the ECU but I don't see how that could just go out like that.
Please help!!!
Please help!!!
