91 civic dx with y7 swap
Discussion in 'HYBRID -> ED-EF / DA' started by importphanatic94vx, Aug 6, 2007.
  1. importphanatic94vx
    importphanatic94vx New Member
    ABERDEEN,WA ORIGINALLY FROM YAKIMA
    i have a 1991 civic hb dx with a d16y7..i am running the stock d15b2 intake manifold till i wire up the mpfi when i get the y8 head..the motor keeps reving up to 1,500rpm then back down to like 950rpm..it does this all the time..i unplug the MAP sensor and then plug it back in when the motor is running then it quits.as soon as i shut the motor off and start it back up it start to idle up and down again..so i unplug the map while its running and plug it back in it runs perfect.i am running the obdo wiring and ecu..please help me
    thanks alot d
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    are you unplugging the MAP or the EACV? if you unplug the EACV (on top of intake manifold on driver's side with green 2-wire connector) you should get a check engine light (code 14), the idle should drop down to around 500-600rpm and remain steady - if it does, the EACV is working correctly and you need to look elsewhere - make sure the engine is completely full of coolant with all of the air bled out of the system (including the heater)
  3. clubef9
    clubef9 New Member
    he's right. itll rev that way when theres air in the coolant system. mines actually doing the same and i have a small coolant leak.
  4. Ryma
    Ryma Member
    My buddys stock 90 rex does this and its the IAC sensor.
  5. importphanatic94vx
    still idles weird
    ok replaced the map sensor and the idle air valve..still fluxuates 1,300rpm down to 950 rpm then back up..like i said i pull the plug on the map sensor well its runing and plug it back in it runs perfect ..soon as i shut the key off and start it back up..idle goes back to fluxuating..
    help help
  6. jlicrx
    Colorado Springs
    did you reset the ECU?
  7. importphanatic94vx
    how to reset ecu
    how do you reset the ecu
  8. Ryma
    Ryma Member
    Unhook your batery for like 3 min.
  9. importphanatic94vx
    ok
    ok if resetting the ecu does not work what is next..there is a sensor below the intake that i heard was callled the cam positioning sensor that is unpluged..its right below the intake /....the b2 block has two wirres the y7 has a one wire sensor..
  10. Ryma
    Ryma Member
    That could be it. My buddys car dident run right cause that wasent pluged in but it still has the IAC sensor out so it does the rpm fluctuating still.
  11. importphanatic94vx
    y7
    should i hook 2 wires or all three
  12. Ryma
    Ryma Member
    I have no idea. you could alwase test to see what wires you should use.
    Try them one at a time and see what wire combos will clear it up.
  13. importphanatic94vx
    help help
    hooked up the sensor below the intake think it was the cps..still idling weird..up down,,,up down...up down..pissen me off..help help help
