91 civic hb plus a h22
Discussion in 'HYBRID -> ED-EF / DA' started by Da Hatch, Sep 24, 2006.
  1. Da Hatch
    Da Hatch New Member
    i just got my 91 civic si and i was looking into swaping a b16a in it but i have a 90 accord with a h22a in it. how hard would it be to put that in to my car or can it be done.the h22a is a 97 type s obd2 .so how hard and how much will it cost if it can be done thanks.
  2. Da Hatch
    Da Hatch New Member
    Or should i just go with b16a in to the civic
  3. engineswap
    engineswap New Member
    well heres on of the guys that used to live in my town(watertown,SD...and moved to sioux falls,SD. http://www.cardomain.com/ride/2137525 over 1000hp in a 92 civic.check him out and leave a message he'll prolly have some info on the wiring
  4. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
  5. Da Hatch
    Da Hatch New Member
    what do you guys think would be best to do buy a b16 swap or use my 97 h22 type s swap and put it in my 91 civic si hatch. i dont know what one i should do or what one would be cheaper .Any help will be fine thanks.
    thanks for the post above
  6. Andrew
    Tallahassee, FL
    Your welcome.
    Since you already have the h22, I would suggest going for it. Thats $1,000-1,500 less than you would normally have to spend!
    I think H series is the route I'll be taking on my next project.(for a drag/track car.).
    However a good point to keep in mind is the condition of your roads.
    As you'll see/read in Explicit's site, the H series sit about 3 1/2" off the ground, and thats depending on your cars ride height already!
    Just an important thing to keep in mind- thats why I'd only go H if it was a track only car.
  7. Da Hatch
    Da Hatch New Member
    I am going to drive it every day plusi want to take it to track on weekends my car is not lowered right now at all i was waiting to do the swap to lower it.also how much do u think every thing is going to cost to do this swap i want to try to get it done before Nov 4. also is my motor going to be a problem since it is a 97 type s obd2 i think. or will every thign be ok just have to but harness. i been looking at mounts at explicitspeedperformance.net.any other sites.
  8. Andrew
    Tallahassee, FL
    Hmm.. You know, I'm sorry to say I don't know exactly all the info on swapping an H22 into our cars.
    I'm pretty sure however that it's not really the best swap for a first-timer(to swaps).
    If you need it done that soon, I would advise against it.
    If you'd wanna go b16, I think it will be a little more straight forward, hence a little easier.
    It's a good thing you mentioned it being obd-2. I seemed to have missed that. It's fairly simple to run obd-1 in our cars- you just run an obd-1 ecu and harness adapter(like from boomslang that already integrates the knock, iab, vtec, and o2 wires), and use your harness, so it's relativly simple to do.
    Running obd-2 however is not such an easy task. I think you would have to run it obd-1, which would require different injectors, alternator, and a different distributor(you'll need distributor wire adapters, like the one in my sig).
    If none of that makes sense.. maybe this'll help.
    H22 swap will require:
    * obd1- injectors, distributor, alternator.
    (perhaps a little modification is needed for obd1 injectors with the wiring harness you choose to run. you see, obd1 injectors dont use the injector resister box our cars do.)
    * ECU for specific motor.
    * ECU conversion harness (for the obd-0 to obd-1 conversion)
    * Mounts for H22 into EF. Explicit carries them. His offer the best mounting location for the motor, and decreases axle stress.
    * Shift Linkage. His site goes into details on this.
    * Custom Axles. unless you wanna pay up the butt for Name-brand axles. Once again his site discusses what to use.
    So pretty much it will NOT be finished in a matter of a couple weeks. Not by a first timer, unless you had a bunch of cash to throw out to cover the costs upfront.
    B16 swap will need the following:
    *ECU. PR3 or PW0. will require wiring in 8 wires. 2 for vtec, 1 for knock, 1 for IAB, 4 for your second o2 sensor.
    *axles. 90-93 teg.
    *shift linkage. home made or bought online.
    *mount kit. bought online..................................> type in "b16 crx" into Ebay's search. you'll find EVERYTHING.
    And thats about it.
    The b16 is SUPER easy to swap into your car- IF you have everything ready. I don't see why you couldn't have it running by November.
    The h22 is a little more difficult, but will yield more power, stock. (you'd probably be knocking on 13's door with good traction)
    Hope my boredom-feeling-like-typing helps.
  9. Da Hatch
    Da Hatch New Member
    thanks i am not doing the h22 swap now i will just go with my first idea and get a b16.Is ther a kit or something to change over to hydro rather than cable when i swap a b16.
  10. Andrew
    Tallahassee, FL
    You punk... I just typed all that for nuttin?
  11. Da Hatch
    Da Hatch New Member
    lol sorry it wasnt for nothing. i need all the info i can get plus more. thanks so much what all can u tell me about b16a swap in to my car.i found a engine with ecu buthaves no trans for 900. what u think it was my friends old motor he took out before he sold it. Thanks for all the info Andrew.
  12. ef8
    ef8 Junior Member
    I know that Hasport made the cable to hydro conversion kit but i heard that they stopped selling it to redesign it since they were having alot of issues with it.
  13. Andrew
    Tallahassee, FL
    I was just kiddin.. thats what this site is for!
    I pretty much sumed it up completely in my previous comment, except I left out that you have to simply dint the drivers side fender well, just a little bit, for Alternator clearance.
    I believe HMotorsOnline carries b16 longblocks(complete motor w/o trans) for around $750. Keep in mind, however, that shipping will probably make it more like $900, but, HMO is a very reputable company, and their motors have low mileage and a startup warranty...
    If it was your friends, did you hear it run? How many miles are on it? Like I just said, HMO's motors have low mileage(they claim 35-55k), so you MAY be better off going with them.
  14. Da Hatch
    Da Hatch New Member
    i herd it run the miles i dont realy know and does the HMO long blocks come with wire harnes and ecu all that good stuff just no trans.
