91 Crx Hf
jdmcrx16xsi
i have a 91 crx hf i am putting in a zc with either a zc tranny or a si tranny need to know if i can use my hf axles with the si tranny and what axles would i use with the zc tranny?
If you use the ZC tranny you need ZC intermediate shaft and some Integra axels. Do a search and the exact axels will come up. Si tranny can use your HF axels.
yes you have to make some custom axels if you use the zc tranny. which by the way is a longer gear ratio (final drive) than the 90-91 crx si . the si tranny is the best you can get for the zc swap.
