91 si civic 0bd 1 jumper CEL light?
Discussion in 'HYBRID -> ED-EF / DA' started by xips(86CRXSI), Nov 13, 2008.
  1. xips(86CRXSI)
    xips(86CRXSI) New Member
    Portland, OR
    K, I have a 91 si with a gsr swap, the CEL light has been coming on, and I don't know how to check the codes for it, it has a boomslang converter harness obd0 to obd1, the ecu is a chiped p28, the engine is obd1.
    I just need to know how to check the codes. Thanks.
  2. D16SiHatch
    D16SiHatch New Member
    i may be wrong. but i believe there is a 2 pin plug near the bottom right of your glovebox. jump the connections with a paperclip or whatever, and the cel should flash on your instrument cluster giving you the codes.
  3. monotech
    monotech Member
    On most ecu jumper harnesses you will have 2 wires usually Orange & blue for checking cel's but in this case Boomslang doesn't wire theirs up that way.
    Heres what they have on their installation instructions:
    Check Engine Light (CEL) codes can be checked by jumping your
    vehicle’s factory 2-pin timing adjusting connector. This
    connector is near the driver’s side shock tower on 1988-1989
    vehicles and in the passenger side interior foot-well area on
    1990-1991 vehicles.
  4. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    shoulda got a harness from rywire.. just touch the blue and orange wires together and boom! your checking trouble codes
  5. red91efhatch
    red91efhatch New Member
    Albuquerque
    Word, so easy!
  6. D16SiHatch
    i have a rywire harness but i don't remember seeing an orange or blue wire.. hmmm i'll have to investigate now lol.
  7. HATCHET_HONDA
    hobart, indiana
    lol yea theres a blue wire and an orange wire in the subharness. you can wire them to a toggle switch to flash codes on the dash..ive bought 2 of these jumpers already..real easy install
  8. jjsJDM
    jjsJDM New Member
    Stuck in Sh*t A$$ New Mexico
    But what pins are they on? one is just a chassis ground, but what pin is the other?
  9. austinav10
    austinav10 New Member
    i have a jumper harness that comes with 4 sensor and a orange and blue wire. Were do I hook this up to?
  10. austinav10
    I have a ef si ecu jumper to obd1 for a z6, there are four sensor that came with it and a orange and blue wiring that I am not sure were to hook it up to.
