i have a 90 hf crx and a 91 si trans. what i need to know is will the hf axles fit the si trans or do i need to swap the axles too? please help me out. if you have any info let me know thanks.
you don't need to swap anything to put the Si transmission in the HF - all of the 88-91 axles are the same at the transmission end - the difference is at the hub end where the CRX HF and Civic STD have the smaller hubs - just put the transmission in and install your HF axles
Your stock flywheel and clutch should work fine. 90-91 interchange freely between all trim levels. The axles are the same on the transmission side, so you don't need to swap either them or the hubs.
