91crxb16
91crxhybrid
:roll: Help please my 91 crx has a b16 swap it runs at high idle no check engine light please help
throttle cable to tight. fast idle or IAVC not working. TPS not properly adjusted. start there
matt
new throttle body and intake manifold gaskets if those suggestions dont work.are all the vac lines hooked up properly?
Originally posted by 91crx@May 7 2004, 11:12 AM
yea just turn the idle down on the throttle body there should be a little screw
yup easiest way, also check to make sure the throttle cable isn't too tight
