92-93 integra ecu
turbo4dr
Member
i have a 92-93 integra ecu running a b18b engine i figured it would run ok but it has an irratic idle and i don't know if this is causing it i have yet to try anything else but i just wanted to know if this could be causing the problem.
what the hell to you mean duh
my question and that shit are so totally different He used a stock ex ecu and chipped it to fit a b16 I have a obd 1 ls ecu and the only difference in the two are the heads and cams
If he is running the LS ECU with an OBD1 B18B in an OBD1 car that should not cause an erratic idle.
