92-95 d15b7 swap into 90 EF?Help!
i need some help here!
im swaping a d15b7 (obd1 /93/ )engine into a 90 EF,Using stock manual cable tranny off a EF.Do i need new axels?. I just finished the auto to manual swap.Just need to wire it all together .Do i need a harness jumper obd0 to obd1? anything else
I don't see why you'd have much trouble running it off a pm6, however i don't know what it takes to get an obd0 dizzy onto a b7 head. It may require some kind of fabbed up bracket, i'm not sure on that. and no you don't need new axles.
best route, albeit slightly more expensive, is to convert to obd1. in which case you would need an ecu jumper w/ subharness for 4 wire o2, distributor conversion harness, and a p06 ecu.
