My batttery went dead and I know I need a code, but also my over head light will not work and the rear defroster will not work now I have checked the fuses under the hood. All this happened only after I restarted.
Thanks in advance
Sounds like you have a LOT of electrical issues. For the fan, listen to see if the relay clicks when the car starts to get hot.
Start checking your ground connections!! Make sure everything is connected as it should be and clean the conenctions. (undo them and wire brush everything back to bare metal)
yo i had dis same problem for me it was da alternator not grounding out properly due to a loose nut jus go to da alternator an pull off da rubber protector an take a look at it but its definetly a electrical problem dis is a good place to start also check ur battery wires an see if there grounding out also
