92 civic b18c1 swap problem with engien
slavka321
i have a 92 civic vx and i dropped a 97 gsr in it and it works but the v-tech dosent work at all and the car is not that fast i have a apexi v-tech controller and it is not helping and it is not throwing any codes.
thats why you have a phone hooked up,, its vtec man not vtech.. but anyways what ecu so you have
man i had the same f*cken problem did you use the cars harness or the gsr harness you have to use the cars and the vacumess are tricky there is a senor at the bottom of the intake manifold you have to take it out. the line from the canister and the fuel pressure regulater have to be t off to the only vacum in the intake manifold hope i helped
