92 GSR axel problems
Discussion in 'HYBRID -> ED-EF / DA' started by fastgsr, Dec 18, 2008.
  1. fastgsr
    fastgsr New Member
    I have a 92 GSR that I can't get the drivers side axel to seat all the way into the intermediate shaft. I have a JDM B18c bottom end and a YS1 transmission. I just need to know how I can fix this problem before it gets worse. Any help would be appreciated.
  2. mikey bottles
    mikey bottles Prof. Bottles
    S. Jersey
    have you tried giving it a knock on the end of the axle with a mallet to try and get it to seat?
  3. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    if you have the right axle, it should go in with a little whack from the old dead blow hammer
  4. branded noooob
    branded noooob New Member
    jackson missouri
    take a block of wood BIG and give it hard steady whops itll,go in ,it can be hard,but it will
  5. gdc2000
    gdc2000 Noob
    Winder GA
    I had to do the same thing as the previous folks said. I used a piece of a 4x4 and took a hammer to it and they went in. I did not have to beat the crap out of it but had to hit it pretty good.
  6. fastgsr
    fastgsr New Member
    Thanks. If that approach does not work what else would you all recommend?
  7. 91_stylin_civic
    91_stylin_civic Member
    New Jersey
    you could always take the int. shaft out and put it together outside the car, thats what i did for my build, just when putting it back in the car make sure the inner part of the axel doesnt pull apart.
  8. fastgsr
    fastgsr New Member
    Thanks 91 stylin civic i think that i will try that approach and see how it works. I have tryed the other ways the other members said this past weekend but none of them seemed to work so I will try this way.
  9. INJEN78
    INJEN78 HS LEGEND
    OHIO
    spray some pb blast onto the end of the shaft and try again with a hammer
  10. jlicrx
    jlicrx Senior Member
    Colorado Springs
    do you have the correct axle on the driver's side? - the driver's side inner CV joint has splines full length where the passenger side has splines only about half length
  11. fastgsr
    fastgsr New Member
    Jlicrx do you know where I can find an intermediate shaft and axel combo that wont cost me an arm and a leg?
  12. tdaug775
    tdaug775 Junior Member
    I am not sure where you are located but here is a site that you can look up yards any where. Car-Part.com. I use it all the time and go under the state I live. Hope this will help.
