92 Honda Civic B18B Turbo
allbottledup
1992 Honda Civic Turbo B18B
T3/4 .50 turbocharger
Ram Horn turbo manifold
XS Engineering intercooler
Turbonetics waste gate with 8 psi spring
Tial blow off valve
94-95 B18B motor with P75 ecu
RC engineering 270cc injectors
B&M Command-flo adjustable fuel pressure regualtor
Performance clutch
lightweight flywheel
short throw shifter
Rear LCA with bar
Upper rear strut bar
Tocikos blues and springs all around
full interior (some installed some not but have it all)
Full downpipe and exhaust 2.5" no cat
What it needs:
Chipped ecu (fuel cut kicks in with boost in higher gears)
Rear fender panel rust (Hard to find an EG without it)
Turbo manifold has two cracks (taken off welded should be cheap fix)
$3700 obo...money talks..best way to contact me is text 845-629-87sixtyone Come check it out
