it should be prewired from the ecu to the shock towers
you will need to add vtec wires from the shock tower to the correct vtec componets(sp?) , I believe hasports makes a harness that will due this for you.
you also need to wire the knock sensor, from the sensor all the way to the ecu, or use a chipped P28
