92 Integra GSR trans problem!
kevs_92gsr
I have a 92 GSR Integra and there's something wrong with the trans I think! Here's the story, I was stoped at a red light and when it turned I sarted off normal and when I reached about 3500 It just gave out. It was like it pop out of gear. It still starts and runs it's just when I put it in to gear and let the clutch out it does'nt do anything! When I rev it up the speedometer goes up though. I have a aftermarket ACT cluctch in it but the stock flywheel if that has anything to do with it. I have no idea what the hell it is and it's been sittin for a week and a half. If anybody could give me some information I would greatly appreciate that! :D
If your speedo is going up that means you diff is turning. I think you lost a CV axle. If you put the car in gear, pull the ebrake and then look at both your axles, I bet one is spinning. If this is the case, you need to replace that axle and you should be fine.
