Hi, I'm new.
I finished swapping a B18C1 into my 93 DX coupe. I swapped in a Mishimoto radiator for a Teg as well. I put in a 170 degree thermostat.
The car runs and drives fine, but it stays too cold. If it idles for an extended amount of time, it gets up to about 25% operating temp. If I take off down the road, the temp needle drops all the way down. I'm afraid this will keep VTEC from working properly if it doesn't get up to the correct operating temp. I was thinking of swapping back to a higher temp thermostat. Any other suggestions?
Also, my heater works, but works less well when I'm going down the road. I think the thermostat is causing this as well, but I just wanted suggestions. Thanks!
