93 EG Lx Swap 00 GSR
Discussion in 'Civic and del Sol - EG and EK' started by edward88, Jan 29, 2009.
  1. edward88
    edward88 New Member
    I have a question.... trying to do a swap for 93 civic lx trying to put a 00 GSR my question is on the wire hardness .. should i use the gsr hardness and use the same fuel rail and everything and run the vtec wires...... or do i use the lx wire hardness and run the vtec wire ???
  2. welfare
    welfare Ancient Member
    New York
    yes, use the gsr harness that is on the engine, it will plug right into your car, also use the gsr fuel rail and everything else, mounts etc.
  3. welfare
    New York
