93 eg with obdo b16
Discussion in 'HYBRID -> EG-EK / DC' started by rex187, Jan 6, 2012.
  1. rex187
    rex187 Member
    austin,texas
    ok so i have a obd0 b16a that is sitting in my old rex just waiting to be swapped. i know hasport makes a cable to hydro conversion but my worrie is on the vvs on the obd1 verses the cable vvs on the obd0.. does anyone have any insight into my problem? i think i can just swap with a vvs from like an integra but not sure
  2. Matts96HB
    Matts96HB . Moderator VIP
    You need to get one from an obd1 or obd2 Integra I believe.
  3. serrilion
    serrilion In my own little world! VIP
    Vermont
    honestly your better off getting a hydro trany...
  4. rex187
    rex187 Member
    austin,texas
    so the if i unbolt the vss from an integra and remove the whole vss assemby from the transmission then in theroy it should bolt up to the obdo tranny.. as far as a transmission swap goes thats out of the question unless theres no other way. i dont have an extra $800-$1300 just sitting around for a hydro transmission.
  5. serrilion
    Vermont
    wow.... there like $500 up my way at most, inless you get one with LSD
  6. rex187
    rex187 Member
    austin,texas
    i have to pay for shipping which is usualy 250-300 so its not that cheap near me away. guess ill keep looking. the main reason i dont want to swap is cause i liked the gearing of that tanny. but if i have to swap ill probaly just save up and get my hands on a pos tranny and throw complete mfactory rebuild in it or maybe see if gear speed is still around now days.
  7. serrilion
    Vermont
    I would honestly look... Like Matt said maybe u can un bolt the VSS from a 94+ integra and use it, my only worrie would be you would also need its harness for the speed sensor...
