93 vx hatch
*motor
jdm gsr motor
lsd trans
nology plug wires
new rings and head gasket
arp head studs
spoon thermostat
spoon temp switch
magnetic drain plug
grounding wires
walbro 255lph hp fuel pump
rc 550cc injectors
skunk-2 intake manifold
hondata intake manifold gasket
crp turbo manifold
percision 650hp intercooler
garrett t3/t4 60 trim turbo
manual boost controller
2.5"charge pipes
3"down pipe
stealthmode oilline kit
greddy type rs blow off valve
tial 38mm wastgate
greddy sp2 exaust
comp stage 3 clutch
comp clutch lightened flywheel
polyurathane engine mounts
chipped p28 ecu
uberdata tuned
zeitronix wideband
zeitronix boost sensor
zeitronix egt probe
zeitronix display
*suspension
tien flex coilovers
gsr lower control arms
gsr swaybars
gsr front and rear brakes
91 ex 15/16 brake master cylinder
*exterior
jdm power folding mirrors
asking $8,000
hit me up at smmccurdy@hotmail.com if interested
*motor
jdm gsr motor
lsd trans
nology plug wires
arp head studs
spoon thermostat
spoon temp switch
magnetic drain plug
grounding wires
rc 550cc injectors
crp turbo manifold
2.5"charge pipes
3"down pipe
tial 38mm wastgate
greddy sp2 exaust
comp stage 3 clutch
chipped p28 ecu
uberdata tuned
zeitronix wideband
zeitronix egt probe
zeitronix display
*suspension
tien flex coilovers
gsr swaybars
*exterior
asking $8,000
