94 Civic Ex Coupe Dual Exhaust
Discussion in 'General Tech and Maintenance' started by thepester, Mar 16, 2003.
  1. thepester
    thepester Member
    Can you put Dual Exhaust on a 94 Civic EX Coupe?
  2. Prowler
    Prowler Super Moderator
    B MT
    Yes, with a Y pipe. Almost any muffler shop will form you a dual exhaust. Performance-wise, it's pointless on an I4. You lose needed backpressure for low end torque.
  3. Tonyd0821
    Tonyd0821 Banned
    so ur saying that when i had my old zc hatch, with a straight pipe (no cat) and a "brospeed" exhaust....(crap)
    i was loosing hp?
  4. thepester
    thepester Member
    dont they make 2-1 headers that you can use?
    and are you sure you would lose HP? my dad said dual exhaust adds HP because the exhaust gets out faster, thats the same as less back pressure right? so i dont know, ill ask my dad. hes been working on cars since he was 15, but doesn't know shit about foreign, just chevys and what not.
    but do they make 2-1 headers?
  5. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    i think honda would have thought of that if it helped. the s2000 has dual but when you buy say an apexi cat back it stays with one.
  6. B16
    B16 Super Moderator VIP
    yay area, CA
    no, you need some backpressure, the ideal size is 2.25" single exhaust. do not go dual
  7. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Even if you did see a slight gain in power, you now have to carry around all that extra weight.
  8. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Yes,but you'd need two of them since you have four exhaust ports.
  9. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    In old domestics and other huge smog machines, dual exhaust will help but honda are engineered to make as little exhaust as possible so if you go dual exhaust, all you will do is relive all back pressure (you need that going NA in a honda) and also carry around an extra 30-40 lbs, Not worth it. Also you would look :ghey: , strait out of Fast N ferrious, sound like crap, and you would be wasting a good 300 on the other exhaust pipe. DONT INVEST.
  10. 2 litre EG
    2 litre EG Senior Member
    so cali
    if you plan to stay all motor then definitely stick with a single exhaust
    a buddy of mine built a dual exhaust hatchback but it was fully built and turbocharged... from the turbo down pipe it was a 3" cat, to 3" piping, Y-piped down to two 2.25" pipes routing out the back of the car... it looked clean to say the least :p B)
  11. thepester
    thepester Member
    what if its comming off a b18b w/ turbo?
    then is it worth it?
  12. pissedoffsol
    umm no.
    cars running 11s, 10s, and 9s all have a sinlge exhaust.
    cars running 16s, 17s, and 18s soemtimes have dual.
    see my point?
