94 ex coupe/f20b
Discussion in 'HYBRID -> BA-BB /CA-CD' started by lilyoda, Nov 28, 2009.
  1. lilyoda
    lilyoda New Member
    I just bought a euro type r. What do i need to do to get it running?
  2. 99sidude
    Ohio
    Connect the battery. That should get it going.
  3. lilyoda
    lilyoda New Member
    well it should be the same as swapping in a h22? Any know of of check list to help the swap go smooth.
  4. lilyoda
    lilyoda New Member
    no help on honda swap? shitty.
  5. 99sidude
    Ohio
    :headsmash:Don't be a jackass. You gave us zero information. It doesn't matter if the car is an f20 civic or an ls1 miata, I'm not going to be able to get it running without any details.
    -is the car getting spark?
    -is it getting fuel?
    -does the engine turn over?
  6. lilyoda
    lilyoda New Member
    the project is a 94 honda accord ex coupe, with a f20b sir-t. so obd1 car obd2 motor. Should be pritty straight forward. Just like to know anything that i should know.
  7. lilyoda
    lilyoda New Member
    im looking for guide lines to getting the swap in with have to go buy this after i find out that i need it. so like mount lines? What ever i need, just shoot it. Thanks for your help
  8. 99sidude
    Ohio
    Well having never done a h/f series swap myself, my input is going to be pretty useless. See if you can find any h series swap info in our reference section. An h22 swap is very similar to doing an f series swap in a civic.
