94 gsr motor 96 civic hatch
Discussion in 'HYBRID -> EG-EK / DC' started by chicken, Apr 5, 2004.
  1. chicken
    chicken Senior Member
    Sacramento, California
    96 civic chassis
    94 gsr motor
    would a 96+ gsr ecu work if i used it for a 94 gsr motor??
    or would i need to use a jumper??
    and if i used the 96+ ecu.. would i have to change the dizzy..??
  2. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    why are you stepping back a generation in OBD? bad news for emmisions inspection-
    a jumper harness would work and wouldn't probably be the route to take for the least amount of problems
  3. E_SolSi
  4. B18Civic95
    B18Civic95 Member
    you would have to change the harness on the engine. It's easier to run a obd1 ecu with a skunk obd2 to obd1 conversion harness for the ecu.(94-95)ecu
