What is this called?? The shop said this is bad. And what colors would be connected on this?
I have a problem on my 93EX with 94GSR. The Car revs up and down. I bought the car with the engine. I took it to some shop and they said that it can be IAC Valve or Fast Idle Thermo Valve. And the harness with the plugs has been cut and but connected the following wires that are cut:
Yellow/blk strip>
>Plug that Idk where it goes??
Blue/white strip>
Yellow/Blk strip>
Solid Red>>>>>
Then there are this wires that come out from a bundle from a wire loom:
Yellow blk strip>
> This plug is on top on my IDK Plug?
Solid Red>>>>>
Green/Whit>>wire?
Red/yellow>>Wire?
These wires are located behind the intake manifold really don't know what to do.Need help on this pls
